Remove invisible shield?
Pseudoty1
Member
I bought the zagg at bb today. They installed it and I dont like it at all. It does not look good, the texture is is not smooth, and it does not work well with swype. They said let it cure for 2 days. If i remove it does it come off clean?
It may protect good but the cheap ones at verizon look better.
The manufacturer claims it comes off clean. I was gonna get one myself, but after downloading Swype I decided against it.
Please post your results so we know for sure.
It will come off fairly clean yes. Might be some residue but breathe on it and wipe it off with a soft cloth it will be fine. I bought those silly (to me) screen protectors from Veriz today and go figure I hate them. I'm going naked and staying naked till steinhall antifingerprint/glares come out and try them.
I'd give it a day or two to wear in. It takes a little while to completely clear up and get rid of the initial stickiness. Then judge if you still like it. I got one for the fiance at BB, but am naked on my own until Steinheil rolls out one.
i say wait for 3 days and let it settle in. you porbably still wont like it BUT it does take a day or two for it to settle in. leave in on there until u do some more research on which protection to get. the incredible just launched so wait awhile and see what comes out. steinheil seems to be a lot of people favorite so wait for that one. just keep it on for now
