Help remove sd card when swapping Droid to X?
Why would you put your contacts on your sd card? Just back them up with google and they will automatically pull over when you get the droid x going.
No, apps wont backup with google. I also doubt the rep will move the card over unless you say something since the droid x comes with a 16gb card.
