great post thanks EM
im still s-on so that does cut down the choice some what i think
It depends on a lot of firmware factors.
You can open (almost) any rom zip on your PC if it has a non-standard Sense kernel and find it with the file name: boot.img
Extract that to your fastboot folder. Then go into fastboot USB mode and say -
fastboot flash boot boot.img
Do that right after trying any rom that bootloops.
S-off means you don't have to do that - and you don't have to worry about bootloops, everything installs.
And that's the worst that will happen - a bootloop (cue scary music, followed by me throwing confetti and saying Don't Panic).
To cure that, you restore to whatever stock-ish rom you like, and you grab your stock rom (the real stock rom), extract its boot.img - follow the procedure above - and profit.
I know that's not supposed to work on HTCs.
I also know I've seen that work more than once.
All comes down to how much experimenting you want to do.
Just so im getting this right. Extracting the boot.img from the zip file will cure a bootloop from a firmware mismatch?
How would a firmware mismatch happen? I thought you could flash to any other firmware (obviously in this case ones made for the international, not just any old carrier) as long as the hboot matched?
Man this HTC stuff is a lot harder than Samsung![]()
