Remove synced contacts?
mj_b90
I first exported my contacts from Outlook to my gmail in order to add them to my Eris. Later I used the HTC sync to import my calendar but the contacts went with it. Is there any way to remove all of these 'phone' type contacts and keep them from being synced again?
import your contacts to gmail, online, on your pc, make sure they are all there
then delete them all off your phone
then delete them all off your outlook
then resync...
should work.
