Root Removing and replacing lockscreen and calculator
s_wall98
So I just flashed Aloysius V11 and really love it but am trying to change 2 things.
First off I'm trying to get rid of the lockscreen and replace it with the HTC Sense Lockscreen (I believe), basically the stock one with a clock on it.
I thought I could pull the HtcScreenLock.apk from the Rom I found it in then adb mount and push it. I tried that but got nothing. I'm guessing I need to remove the one that came with the version I have first but I'm having no luck.
Secondly, I like the stock calculator better than the one that comes with all Aloysius Roms (that I've seen anyway) and I'm not real sure how to replace it.
Any help would be greatly appreciated.....and yes I have search here and XDA
Thanks
Thanks
FOr the HtcScreenLock.apk you have to give it the right permissions i believe and then reboot and you should be able to see it
Code:
adb shell mount -o rw,remount /dev/block/mtdblock3 /system
adb shell
su
cd /system/app
chmod 775 HtcScreenLock.apk
exit
exit
adb reboot
The above code should make your lock screen come back
As for the calculator one do the same thing but with the calculator app.
Code:
adb shell
su
cd /system/app
exit
exit
adb reboot
Sorry to get slightly off topic but I have been trying to search and havent been very successful. What are the various chmod number permissions out there and their corresponding permissions they grant? Or if you have a link that provides all this I would be interested in that as well. I can wiki chmod but I'm not sure if that pertains to us or not. Sorry if thats a newb question.
