Root removing bloat ware help.ASAP
Can someone help me with a step by step on removing bloat ware . I have root explorer. But when I try to remove them it says cant be removed it is read only. Please help.
are you rooted why not just run the script thats on here it gives root and removes the junk
I am rooted and have root explorer. maybe I just dont know how to remove the junk. I also have root checker and it says I have root access. When I pick a app to remove I hold it down and select delete is that correct?
Titanium Back up has what it calls a "Chuck Noris" mode... that was the only way I was able to remove most of the Metro bloatware crap... and then I had to pull the battery in the process do finish removing some of them, but it did work for me.
How do i get into Chuck Noris mode?
