Help Removing Bloatware
Opticman
I tried through Settings>Manage Apps......but you're not given the option on the bloatware to uninstall.
How do you guys remove this crap? Do you drag the icon down to the trash can?
Thanks for your help
Deleting icons on home screen doesn't remove apps. You need to root the phone to be able to delete bloatwares. That's what rooting is for.
