Removing bookmarks
Blizzard
I can't figure how to remove bookmarks that I have created. I can remove the icons, but they still show on the bookmarks list.
While the browser is open press the "menu" softkey on the bottom of your phone screen. When the options menu opens, there will be a touch screen selection marked "bookmarks." Press that and it will take you to your bookmarks screen where you can long press to remove the bookmarks.
I tried the "long press" and dragging it to remove, however.... that removes ALL bookmarks, not JUST the one I want to remove. Any suggestions??
the directions are semi-correct at least on my phone........
open browser>select menu> (heres the difference) select navigate>long press the bookmark you want to edit and a menu will appear
