Help removing/deleting bookmarks
Browser> Menu: Navigate> (now you should be looking at your bookmarks) Menu: Delete
Now, you should be looking at a list of your bookmarks. You can mark each of them on the right that you want to delete....then press "Done"
Sultan, thank you for info, when i applied the process to my friends HTC eris droid it worked like a champ (she thanks you also), however, mine is a motorola droid with the qwerty keyboard and i am so far not able to use the same process to delete the bookmarks. I am going to apply a fine rhum this evening and see if that helps and if you have any other ideas i would greatly appreciate them.
hhmmmm....i have an Eris and haven't tried to do this on a Droid (and, I'm in Dunkin Donuts waiting for my car to be finished so I can't go find one! lol)
If I were you, I'd open your browser and checkout every nook and cranny of your Menu you can, it HAS to be in there somewhere.
Another point, does your friend's Eris have 2.1? And, does your Droid?
Delete a bookmark the same way you delete a single history item. At the bookmark screen, touch and hold the bookmark you want to delete. After a second or two, a menu will pop up, last option is "delete bookmark".
Works for me.
Jerry.
