Root Removing Drakaz recovery
gil1
Hello,
I rooted my phone today using darkatz recovery, went smooth.. zero problems (Also did nandroid backup).
My question is, is there a way to remove the darkatz recovery image and revert to stock, basically remove all traces of Rooting (If i ever want to get firmware update from operator).
Thank You,
Gil
Just do a wipe from recovery and then re-flash a stock rom with Odin and it will be a 'virgin' phone again. :)
I don't have the stock rom of my operator (Orange Israel).
Is there a way to restore only the recovery image?
I am new at flashing and rooting so this question might just be stupid.
Hmm. I guess you can first unroot your phone from recovery, then flash the recovery from a similar (to your original firmware) stock firmware the same way you flashed Drakaz firmware - via fastboot. I've not tried it. Try at your own risk.
i think you can
