removing files from system folder
is there any app i can use to delete files from the system folder??
am not trying to delete preloaded apps but a file that wont let me install lag fix
you probably cant install it cause theres not enough space in the /system folder. if you want to delete some stock apps use systemapp remover. and if you want to delete some other stuff (just be careful what you delete to not brick your phone!) use root explorer and navigate to the /system folder
the thing is i installed oneclicklagfix v2.2+ but then uninstalled it to try oneclicklagfix v1+ (dont ask y lol) but then when i tried to install oneclicklagfix v1+ it said
you already appear to have
another lag fix installed! (/
system/bin/playogos1 less
than 5kb)
well dats wat i need help on idk how to delete it i tried the app systemapp remover but it wouldnt let me delete files in the system folder
the systemapp remover allows you to delete apps only. use the root explorer and then navigate to the folder you want to delete ;)
well i tried using both apps but it wont let me it says that the file is read-only
i would like to know if you know how to make it writable?
oops i think i spoke to soon i tried installing the lagfix then it said will reboot to make sure everything is well but when it rebooted it wouldn't turn on it does the Samsung sign but doesn't do the t mobile sign and all it does is vibrate idk what happened
lol. u bricked your phone. what did you do? maybe you removed some file you shouldnt. now you have to odin back :|
lol yea i got scared but i got it and i think that was the best thing that happened to my phone lol before i couldn't flash a rom on it and now i could am using Eugenes Ginger Clone 2.2 Final R1
