Removing old NFC sticker
psf57
Qi/NFC sticker coming today. Question is: Easiest way to remove the old NFC sticker (810)?
next question. I normally would just buy a wireless back, but only have the circle ones. Okay, Installed the sticker, works okay. BUT, it came with this other sticker that has a silver sticky backing. What the heck is that for. No instructions on this thing. ugh
Ahh, took the old one off. Seems it would have been to thick Thanks :) Working good, at least the Qi part. Haven't checked NFC yet.
May I ask where you go the sticker from? And does anyone know if they will work with the leather backs?
They can be found on eBay, among other places. I got one right away, and it did not fit well inside the leather back. It worked (more or less), but prevented the back from sitting properly, causing the back to not sit flush around the camera. You wouldn't think 1/16th of an inch (or less) protrusion would matter, but it completely changed how the phone felt in my had, enough so that I pulled the sticker out.
I'm hoping a thinner one is available elsewhere. But all of the ads I see look to be the same sticker.
Yeah, got mine from Ebay (China, took a little over a week) and I know with the gray plastic back it's a tight fit. Thinking that's why the OEM Quick Circle fit differently over the sides of the phone.
