Help Removing Weird Dialer Popups
rexesq
I have this weird problem with the dialer screen. After I dial and hit the greeen for go button, I get the following yellow popup at the top of the screen:
It contains text of the geographic location [always incorrect], the time [usually incorrect], and a person's name. It's almost like a caller ID of some sort, but it does not corrspond to the person I am callingAfter a few seconds, the yellow popup fades away and I get the following, which looks like a white field in which to enter date [it won't allow data entry, though:
It also happens when I receive incoming calls.
Now, I realize it's probably some app I have installed, but for the life of me I cannot figure out which one it is. These artifacts are very annoying because they cover up the caller ID info on the dialer, as well as all other info at the top of the screen. Does anyone know how to get rid of these popups without doing a full factory reset? Ugh.
I've never heard of this. Have you installed some sort of alternate dialer, SMS program, or launcher app? As you said, it's probably some app you've installed because default Blur does not do this.
