Help Removing words from default dictionary on Samsung Galaxy S4
I do not think you can remove words from predictive text. What happens over time when you use your keyboard the words you need get on the prediction board and highlighted because you have used them so much. The predictive text is pretty good but not at first because it has to be adapted to you.
Another solution which I really recommend is Swift Key keyboard from the market! Prediction is awesome and plus it has a ton of goodies.
