Root Rename backups
silverxbv2
I like having dates on the nand backups, but can I rename them without ill effects? It will still load them up with names instead of dates right? Dumb question I know.
NAND backups can be renamed to whatever you want (as long as you don't transfer it to your computer and rename the file extension or something.) I have done this with all of my NAND backups using ASTRO file manager for organizational purposes. Go ahead its safe.
yea thats what i did was rename them while they were on my computer then when i transferred them back to my phone it wouldn't flash. i may try to do it in astro next time.
