There's a thread on this forum about Unrooting orange. I'm ony phone otherwise id search
It out for you. Either search this forum or Google unroot orange desire xda
Where are the smartarse comments? You asked how to get back to stock and you've been told that unless you've got an AMOLED screen you can't. Your only other choice is to put a stock WWE ROM on and hope they don't mind/notice
I gave you the exact Google search term. You didn't do it so I did it for you. It was the first result.. if you don't do the search yourself (which I since have proved it was easy) then you should expect smart arse comnents. We can only help you to help yourself.
If you can confirm its an slcd phone, its useless anyways.
Best bet, get to generic stock
Edit. Folder probably called clockworkmod BTW
You could create the file structure of a nandroid backup but if you did a nandroid and it doesn't show up on your SD card then something is wrong...it won't be on the SD card under nandroid, it's normally under clockwork mod (if that's the recovery you use)
Otherwise, download 2.10.405.2 from here and flash it using a gold card:
Shipped ROMs
Phone is working apart from 'connect to a network' function
So..Go ahead and create a gold card.. Unrevoked has nothing to do with it.
I dont want to piggy back on this thread but to clarify things for new users is a blank gold card all thats needed to be able to put a debranded phone back to stock if something went wrong with it!.
i.e I have made a goldcard of a 4 gig samsung card.
But I also have an 8 gig san disk I wish to use in my phone for day to day use etc (keeping 4 gig as a back up).
P.s is a gold card needed for normal use as when I put the 8 gig card in formatted Fat32 I cant install apps to the phone anymore?
(if a mod could split this thread |I would be grateful)
