Help Repeated Loss of Data Connection
Catwink03
I lose my data connection on my DInc4G atleast once every day. I am able to regain my data connection by either restarting my phone or toggling on/off airplane mode. However, I would like to prevent this issue from ever occuring.
Anybody else experience this issue with their phone?
Have not tried that yet. I have a replacement SIM card, so I'm gonna swap that first and see if that helps at all.
If not and if nobody else has any solutions, I will try the hard reset.
Yes...yes I am. Exactly as you described it.
Ditto.
Me too. Mine is fixed by turning off Wifi when I leave home because my phone thinks it's still connected to my home network when I leave. I contacted HTC and they sounded as though they're aware of the issue.
Yep... I've encountered that same issue. It won't let go of my home network when I leavethe house. Sometimes toggling wireless off/on will fix it. doesn't happen often but is annoying none the less!
This happens to me as well quite frequently. I will try toggling wifi off and see if it helps at all. Does anyone have feedback if this for sure is helping with them?
