Root Replace battery icon
sequre
Is there a way to replace the battery icon on my status bar to show the percentage in the middle? I am running no custom roms, but is there a way to metamorph a file, or even push a file into recovery to make it happen?
Yes, any theme that works on a sense rom should work with stock. Look under the virtuous or ihftp section of rom manager for some themes. Do NOT do a wipe when applying. Of course do a backup first.
Or can look around xda for battery mods for sense roms.
sorry, should of clarified, any mod from a sense rom that is built from the incredible's framework should work. Both the mods you tried to use are based on the evo and will not work.
