hey,
i got some private certificates i need to install on my rooted htc desire.
i copied /etc/security/cacerts.bks and added my cert
then i tried to replace the old cacerts.bks, but i failed everytime.
i need to install those certificates, but i don't know how.... any ideas?
kind regards
eadwig
Code:
# keytool -keystore cacerts.bks -storetype BKS -provider org.bouncycastle.jce.provider.BouncyCastleProvider -storepass changeit -importcert -trustcacerts -alias CACERT -file mycert.crt
- 1. mount /system rw
- mount -o rw,remount -t yaffs2 /dev/block/mtdblock3
- adb remount
- 2. replace /cacerts.bks
- cp /mnt/sdcard/cacerts.bks /system/etc/security/cacerts.bks > cp: cannot create '/system/etc/security/cacerts.bks': File exists OR rm failed for /system/etc/security/cacerts.bks, Directory not empty
- dd if=/data/cacerts.bks of=/system/etc/security/cacerts.bks > 123+1 records in
123+1 records out
63285 bytes transferred in 0.015 secs (4219000 bytes/sec) > ls -l tells me, that the filesize changed, but after rebooting the htc it's stil the old file. - adb push cacerts.bks /system/etc/security > failed to copy 'cacerts.bks' to '/system/etc/security/cacerts.bks': Directory not empty
kind regards
eadwig
