Help Replace LCD Display Screen for Metro PCS LG Optimus M MS690
BRIAN5337
I am trying to replace a LCD screen or maybe possible a Digitizer. I'm not sure which i really need. I have never replaced a digitizer or LCD. I have found a few locations to purchase both but i would like to know a little bit more about the process.
Thanks
Digitizer or LCD Display Screen for Metro PCS LG Optimus M MS690
When you find somewhere to buy the screen please let me know so I can have a back up screen.
i have looked with no luck for a replacement screen.
There will never be a screen available for the lg optimus m ... metro makes way to much money off there phones! Then they have there sidekick insurerion who in the end shoves their pole even farther up your! Your you know where. Find a independent shop and see if they have on that has water damage. Normally water destroys the chip set not the digitizer.
I found this eBay listing not sure if it is what i am really needing. I just am unsure of the pressure point on phone to be able to snap open after removing all screws. When i try to open by applying a prying motion it just feels like I'm going to break the outer casing. I know sometimes there are hidden tabs that hold two molded front and back together. I wish i knew there location to be better able to open with out breaking phone.
LCD Display Screen for Metro PCS LG Optimus M MS690 | eBay
Thanks. I see that there is a digitizer and an LCD screen on that site. What is the function of both.The front of my Optimus M has no cracks on front.
It seems like the inner part of the screen has been distorted.
The screen light comes on and that's when i can see the distortion but nothing else.
Any help is appreciated..
Thanks
