Hello,
I am wanting to buy a replacement battery for my HTC Hero and I have some questions.
Thanks a lot for your help!
- Are HTC Sprint batteries compatible with the European (GSM) version of HTC Hero? If not, how should I search for a compatible battery on eBay?
- Can I trust eBay sellers who sell the original(?) OEM RHOD160 for just $10/piece?
- Are there any drawbacks to using aftermarket batteries instead of original HTC stuff?
. And I dotn complain but since I rooted and have custom rom cant tell you its better
. To the 10 dollar pieces. Well are you buying a huge one or just a replacement?
