Accessories replacement batterys
erry
Ok, ive tried all the calibration tricks, I've cut down the screen brightness, I know about turning 3g on and off and everything else. etc. blah blah blah
This ISNT a thread about ways to save battery power or get the best out of the CURRENT battery, its about replacements.
Has anyone found any that worked and were they worth it? And if so which?
cheers in advanced!
For the 20 dollars I spent I got a 3000mAH battery (just over 2 times as big as stock battery) a new back cover to fit the battery into and a charging dock/battery charger.
Having said that my 3000mAH doesn't last twice as long but it is handy for a long time between charges or if you know your going to be using GPS a lot or something like that (I went on an amazing race sort of contest once with an iPhone and ran out of battery half way in). Jump on eBay, you can pick up a deal on there , most mobile phone specialists will charge you an arm and a leg for a spare battery and cover
anyone know what the largest size battery is you can get, that doesn't require a replacement back for the phone?
and is it worth getting or not?
