Help Replacement Droid being recognized on my PC as Android ADB Interface
Ammika13
My old droid used to work perfectly with my PC but this one i cant access the SD card or anything. where can i find the old moto drivers and delete them and then reinstall them? I had to root on a different PC so I know the droid works its just my Windows 7 when it initially installed screwed something up. Thanks
Plug in your phone, right click on My Computer, go to properties, pick Device Manager from the left pane. The device should be listed here somewhere. Try finding it and right clicking and pressing uninstall. It might work. After this you might have to unplug your Droid and plug it back in.
