Replacement Housing for Ascend
lmarisy
Member
Hello everyone! I dropped my ascend and the Screen cracked on the lower right hand side, the LCD is fine, its the screen that broke, is there anyways i can purchase a complete housing for this cell? or am i basically screwed ? :) ive searched all over the net with no luck on screens for it, just the LCD or Screen Protector i was able to find..
Thanks in Advance!
Louie
Check the classified ads section here @ ANDROID FORUMS,or,place your own ad there.
Thanks in Advance!
Louie
Have u check eBay maybe
u can buy a use or broken
For part or if u got insurance
clam lost, get a new one and save the broken
one. For spear
Text. Red Cross 90990 & Donate
I believe you'd have to replace the whole screen. Which means you'd have to replace the whole LCD screen. Depending on where you go, It could be upwards of 35+ dollars. I don't know how much you spent for your phone, But depending you might just need to hop on Craigslist to just get another one. X.x Ask Metro, If you've got insurance you should be able to spend around 50 bucks and get a new phone (I think they give new ones, I hope they don't give refurbished ones.) Good luck!
The screen you are refering to is the capacitive touch screen which is seperate from the lcd screen itself. You don't need to replace both if your image looks fine. I actually had a broken ascend with a good capacitive screen and broken lcd screen for sale on ebay. No takers so, I still have it. Let me know if you want to make a deal or if you just need some help. I have repaired 2 ascends so far. They are extremely simple to work on.
Yes the LCD is just fine i need the Capacitive touch screen, i would love to make a deal and get my hands on that screen please get back to me if you can..
Louie
A friend-of-a-roommate just got this phone about a month ago and already broke the screen, and was curious if I could fix it... so...
... well, can I? According to Google, this is the only relevant result for my searches, and it leads to a Private Messaging-induced dead end. While it's all well and good that ONE person got their screen replaced, anyone else reading through this thread is SOL!
Perhaps I could get some info on the same type of replacement? We don't need the LCD or the touch - although I understand the capacitive touch is part of the cracked front glass, so I guess that'll be the "part". But where to get one? Google has been entirely useless to me except for finding this thread...
Any info would be much appreciated :)
The only way I found one was to buy a bricked ascend on ebay.
I dropped my phone and my screen is totally cracked everywhere, can someone please tell me where i can go and get this problem fixed. I live in the state of Kansas.
How much $ could i get for my cracked huawei? Its just carcked at top right and its not that bad. I was thinking about gettin an lg optimus for virgin mobile and sellin my cracked ascend
I guess its my outside screen or whatever, But I dropped my phone and the outside screen is busted, It still works, But it goes crazy sometimes, Where can I get a new screen?
I have the huawei ascend h866c model by straightalk and my screen is also cracked. Everything works on my phone. The pictures are still clear. I need to know how much a screen for this model is going to cost and how to put the screen on. If I can I would like to try and do this myself. The LCD appears to be fine, from what i have read on here. If anyone has the screen I need please message me. Thank You!
