Try doing a image search through google to see if it shows, then a lot of times it will have a link for it when you put your mouse over the pic. Then you might be able to find where you can get it, or just copy the pic itself and if your using GO launcher or one of the other launchers that allow you to use your own icons to replace the stock ones, then you just use it. If you can't click and save the pic- open the pic from google images, and use a program like Irfanview, then drag the pic to Irfanview, crop if need be and save. Then transfer to your phone and you should be good to go.
