Accessories Replacement internal Battery door/flap ..HELP!
kennyk11
The little battery door/flap that clips into place which holds the actual battery in place and covers the SIM card (not the black battery cover/antenna) has broken!!.. Now whenever the phone drops or is handled rough enough to cause the battery cover/antenna to come off, the battery slides out of place and the phone turns off.. this happens multiple times throughout the day..i'm ready to throw this phone into the far reaches of this galaxy to say the least:mad:... if thats not bad enough, the little chrome peice that surrounds the sensor part of the optical trackpad on the front of the phone has fallen out .. it really takes away from the beauty of the phone!.. any idea where I can find replacement parts for these:confused:???.. used or new, it doesn't matter ... If ANYONE can help me i'd be indebted to you for ever!!!
You would probably like to search google for HTC Legend Replacement Parts. you would find something on ebay, if not. just keep on trying on google. all call up HTC themselves and order a new part.
