I know there have been several threads on this topic, but none of them seem to be quite the problem I have, and the ones that seemed to be the same ended without a solution.
I had a Moto Droid, Android v. 2.2.2, non-rooted. I had "moved" 90% of my applications to the SD card. I did this manually, and I never used any backup software. (I didn't even understand the point -- why backup to the SD card if they were already on the SD card or on my account?)
My phone's screen broke. They sent me an identical replacement.
Before booting up my replacement, I inserted my old, undamaged SD card. I then logged in with the same Google account. My photos and music were there. Soon my phone started download my apps.
However, it only downloaded the 10% of apps that I hadn't moved to the SD card. 90% of my apps were missing.
I downloaded Astro filemanager, since I heard I could use it to "restore" my apps, but I guess since I never backed them up it couldn't do that.
I went to my online account and saw all my old apps. I re-downloaded one of them as a trial, but it downloaded as if it were completely new -- it didn't find my old data.
My questions are:
1) Is there any way to find my old apps on my SD card, and install them directly from the SD card? I'd prefer not to root my phone.
2) If not, is there a way to re-download all my missing apps such that my old application data remains?
And why-oh-why didn't it just re-download the apps properly the first time? Is "move to SD card" broken? Did they forget about reloading apps on the SD card?
Thanks for any help,
Sam
My questions are:
Sam
