Well had a replacement droid sent to me since my 39/09 droid is on the fritz. The screen is basically unresponsive and of course the proximity sensor issue. Anyway, the one they sent me is a 49/09 and its really clean for being a certified refurb the only issue I have is the keyboard. I was one of the lucky ones to get a bubble keyboard and the new one is flat, but the plastic keys are all lifted on the edges to where you can take your fingernail and basically pull it/lift it off on more than half the heyboard. I promtply called vzw and they are sending out another replacement, but do all of the new droids have this keyboard issue? I'm not going to be happy if they send me another one with the same issue. I would love to get another bubble keyboard but pretty sure they don't make them that way anymore.
Any input greatly appreciated!
