rocky s.
Well, here I go...I'm entering the t-bolt replacement zone. I probably wouldn't have sent for a replacement had it just been a matter of some reboots since this will apparently be corrected with a software fix. I confirmed this with htc today when they actually stated that they are still suggesting that verizon replace phones suffering lots of random reboots, but then recommending that users avoid downloading the current software update if not already installed. They pointed out that this way someone can have a working phone (i.e. non-rebooting) until the newer update is released with the fix. At least that tells us it's on the way.
So, why am I replacing? It's because the only problem with my t-bolt is that the camcorder audio issue was not fixed with the update. Yep, guess I'm one of the few unlucky ones that this did not help in that department. Given that this is not a widespread issue and was apparently fixed for the majority with the current update, I'm guessing they probably will not address it in the new and improved version being worked on. After reading sooooo many who have had multiple replacements...with each one having a different issue...from lots of reboots to quick loss of battery power to gaping light leaks...I'm just a little worried about the the risk of ending up with something worse. I'll definitely have some pondering to do when it arrives tomorrow. Geez, what a giant 4G game of chance!!
Place your bets anyone?
