replacement S Pen
thesmeee
Hi all
Looking to get a Note 10.1 in a few weeks, after trying them out verses the new Ipad i was seriously impressed, the only thing i can say that let it it down was the build of the S Pen itself. dont get me wrong it worked great but it made me wonder if there were any replacements available as an upgrade?
Hope you can help
Paul
There are original ones on eBay.
I'm hazarding a guess that by original you mean the S-Pen that came with the Note 1. If so, I believe they're shaped just a little bit differently and the Note 1 S-Pen may not fit into the Note 10.1
Can anyone with both please confirm or deny this.
No mate, we are talking about Note 10.1 and NOT Note 1. There is such device as Note 1, BTW, so please do not introduce confusion where there no reason for it.
Hi all
Hope you can help
Paul
This is the pen and holder that makes it feel and look like a regular pen.
Galaxy Note 10.1 S Pen Holder Kit | Galaxy Note Accessories
This is the replacement
Galaxy Note 10.1 S Pen | Samsung Tablet Accessories
thanks for the links, pretty much exactly what i was looking for, hopefully as this unit catches on a better range will become available
Thanks again
Paul
Thanks again
Paul
Yr welcome. I used it for 3 hrs the other day taking notes. It's not perfectly comfortable but it's not bad either. I would like if it was just a little longer ;)
LOL. Thanks again for this tid bit. The S-Pen Holder accessory for the 10.1 is actually the origninal Note's S-Pen put into a larger casing. So it looks like the old S-Pen will work with the newer 10.1. :D
I'll probably look at it later in the week if I can locate a store that has a display model.
If you are in the US Best Buy has them on display
In Canada and the Best Buys here also stock them. I noticed Staples has them also for a dollar less and I have a Staples that is walking distance. Just hope they have a display model and save me from travelling. ;)
