replacement
screennamie
I'm currently the proud owner of a droid eris. But feeling the need to switch.
I like this phone a lot and I've rooted it trying other roms. Going to give kaos a try later tonight.
The issue I have is with the silent bug.. is this only a root problem or does it occur on unrooted handsets as well?
If I unroot and take it back into the store is there a possibility that they would let me purchase or upgrade at a reduced cost to the droid2 or even the incredible?
After all the threads I've seen this is a hardware issue that has caused some horror stories.
I really would like to keep my phone. I fought tooth and nail to root it and love all the custom roms and wifi tether and can't get enough of the pinch to zoom. Just wondering what my options are if I should unroot if it will fix the bug or have to get a new phone...
If I get a new phone I might as well upgrade :rolleyes:
