DEATH2ALL110 MADE A GREAT UNBRICK TUTORIAL AND WAS KNOWN TO WORK FABULOUSLY!!!
But there has been word of some failures with this method due to LGMU (LG Mobile Updater) causing a fatal error/crash. This is not Deaths Fault!!!
he may have possibly saved you from purchasing a new phone and/or terminating your account with verizon and here is why
1. You tried to use his method and it sent your phone into a bootloop.
OR
2. You began to install the software and caused a fatal error which wont allow your phone to leave the "DOWNLOADING... DO NOT UNPLUG" Screen
here is what you HAVE to do, and i kno this works bc i get the joys of starting over with a brand new ally
Verizon is on overstock with the Allys and has a online deal to get the allys for FREE. so this is no problem to replace.
YOU MUST CALL VERIZON!!!
When they ask you why you are calling tell them that you used the LGMU to update to the froyo, you followed every step carefully and installed the drivers and made sure your phone was properly connected to you PC/MAC. Your phone made it to the Installing section of the update and x% through your LGMU crashed and said you must restart. Once you begun the update over again you recieved a message on top of the LGMU stating there was a fatal error and could not complete update!
from there verizon will submit you to a tech support and explain to him/her the same situation and after doing so they will refer you to either go to a local VZW store to have them flash the software on to your phone and if the flash fails verizon will approve to give you a brand new ally if available in store or ship you one overnight if within Overnight Hours
if this is a success i ask you to donate to death2all110
If you are kind enough to thank me then its much appreciated
Your Fellow Ally
-LiLG37
get it... ally (Allie) LOL
OR
Your Fellow Ally
-LiLG37
