I replaced the touchwiz calendar with the stock android calendar using the guide at xda-developers - View Single Post - Stock 2.1 Apps working on Vibrant and like many people had the gray bar on top which was annoying. Some people mentioned that you needed to replace a timepicker png file in the framework-res.apk file, but I found that you actually need to modify the textfield_disabled.9.png file to a transparent image to make it work(at least on the fascinate). I don't know if there are any negatives to changing this, but haven't noticed anything yet and best of all I now have a much better working calendar.
