Ok back to work after a long day at the kob ill get on it and update soon.Did you update to 10i? you need to do that first.
Then go into developer options and make sure debugging is on. you get Dev Options by going into about phone/software info and rappidly tapping on Build Number. then try upgrading using the tool. also wouldn't hurt to make sure that Enable OEM unlock is checked in Dev Options.
Thanks you everyone.. Finally rooted one click finally worked.. Free tethering one the way.
