Root reprogram phone after cm7 install???
allmanallpimp
need to reprogram phone after installing cm7 aka mdn, min, sid... anyone know how to do this? the ##626* doesn't work. thanks!
Custom ROMs break the options you need in the dialer app, which is why those codes don't work. This can also cause OTA activation to fail in some cases, which I experienced when I was trying to get my HTC Droid Incredible working with MetroPCS. I had to flash a complete stock ROM on the phone before activation would work.
You might be able to set some of these with a tool such as QPST or CDMA-WS, but I don't know for sure. I had to use QPST to program my info into the Inc, but I don't remember all that it encompassed at this point, other than not touching ESN/MEID.
If you're w/CRICKET, try *228
It's been awhile since I flashed a ROM,but,while w/CRICKET,I never had to mess w/mdn/min, etc....
The only other thing I had done was verify the APN was set to CRICKET. You can do this w/various apps in the MARKET or use VOICE search & say "OPEN APN".
Hope this was of some help,if not for you, then perhaps for someone else.
well, i did the install of the rom for a friend, she just put the phone in my hands... looks like qpst might work.... thanks!
