Root [REQ] Find A Way Gameloft WiFi & SD Requirement
Austrie
Android Expert
This is thread is dedicated to find a way around GameLoft games requiring WiFi connection, and being able to transfer game packages downloaded to internal storage instead of keep it on SD Card(for some of us still using a 2GB SD Card :().
Share anyways you know.
i second this! :D i am also still using the 2gb sdcard that came with the phone lol...
oh by the way, i found some 16gb sdcards for like $20. if you want links just say so. :)
maybe something like partitioning some of the unused memory and hacking the phone to think its an sd card then making the sd card another external storage maybe???
EDIT: or some type of crack that makes the app install and read from a location on the internal storage?
Yeah that would involve re partitioning the phone, which I would imagine would be very dangerous lol! Probably much easier tog et a 16gb card, they are really cheap now! Mine is just a class 2 but I get upwards of class 6 read and write speeds. It's been a good card and has been repartitioned many many times while on the intercept.
As for the wifi, you would have to change stuff in the apk itself. Need to read up on bytecode modifying lol!!
What is the link? Do you know if they are SDHC (or whatever that acronym is)?
id like the link my sister could use a bigger sd seeing how she uses the phone as her pmp. not to mention she recently discovered the greatness of cm7:D
