Root [REQ] Red & Black Themes For CM7 or MIUI
Austrie
Android Expert
I was looking for links to free red and black themes for MIUI and CM7. Any you find that are free just post them over here.
I'm currently using Red Remix for CM7, I need something to compete with that...
Austrie check this out... i've ran this before. (miui)[theme] red crystal - RootzWiki
[MIUI][THEME][18.09] Neon Series (RT.GT.BT) - NeonRT Released - Page 10
This is one id recommend! theres also blue and green versions just go to the first post on page 1
Instructions: Unzip the .mtz file from the zip and place it in your /sdcard/MIUI/theme folder, then apply using theme manager. MIUI Theme Manager can sometimes be quite fussy, so if anything doesn't look right try applying the theme again.
Direct link: NeonRT-1.0.zip
