Root Request for a port of CM7 mod for micromax andro A70
what type of help you want.
well, porting is not a one day task it requires good knowledge and a bit of developing skills
if u have got enough time i an ready to help
your profile states that you are running cm7 Beta. can you please shed some light on how you did it.
I'm interested in porting cm7 for a70.
It will be very kind of you if you share with us what steps you did for poritng beta.
since porting is a bit tedious. we will help in all possible ways so that the project carries off.
thanks in advance.
all the best.
PS : if you can share the kernel tree and your idea of porting I can try to compile it on my linux rig.
Upvote 0
BEST TECH IN 2023
Smartphones
