Root [Request]Mi-flavor lockscreen.apk
Krsmqn
Member
I know there was some discussion a while back about the location of ZTE's stock long-press lock screen being buried somewhere in the framework or where ever, but I would still like to request an apk version (if possible) that mimics the original as closely as possible. I know there is an apk out there called Set Ball Unlock which is the closest I have found so far... but the settings are virtually none. No pin lock. No custom shortcuts. Etc....
Anyone up to the challenge?
Thanks (in advance/either way)
I am a bit confused. The stock source rom comes with the long press lock screen does it not? There is not an apk for it, and you are correct it is part of framework-res.apk. There is an apk called Mi-EasyAccess.apk that allows you to customize the zte lockscreen, is that what you are asking about?
I am referring to the whole thing. If someone was able to make an app that was able to duplicate the long press lock screen with the mi-easy access included, that'd be what I am after. I like the look of it and the way you choose the shortcuts... The whole thing.
Why not use the framework-res.apk from stock? You must be on a stock based rom, right? You may lose some other customization in the rom you are using, but otherwise it should work fine as long as you are on a stock based rom.
