Root [Request] Please test for me please, will further development/debug issues
Ok, I have done as you instructed and will keep you informed of the results. Is there something I can do to keep it from prompting me to install the system update?
No it will fail, options are no oc (which is unstable anyway) with my rom or add fotakill to stop ota from downloading
So I'd have to revert entirely to stock to take the update? Should I do that or do you think it will be included in future Rom updates?
will be included in future updates.
if you havent taken the update, please let me know if my rom works. that was the whole purpose of this thread, to get info from anyone who may not have taken the OTA yet whether there is an impact from the OTA which may be causing difficulties
I'm using it right now without the OTA. I've been trying to tell you that:rolleyes: ....I flashed it just fine with Philz recovery and the old update binary.
You obviously had to revert back to stock or were on stock with no root right? I mean because you'd have to be on a stock recovery to flash an official update. Or has been in my experience. Did you lose root after the ota?
Extract the update and remove first two lines from updater script including semi colon. Rezip with normal compression, Toggle zip verification, and cwm will flash no problem.
Have you had a chance to run my rom through some paces, see how it performs, are you experiencing reboots or lock ups and bootloops?
