MarmiteX1
Hi there,
I am not sure what i should do.
I rooted my n4 back in March of this year and been running stock android 4.2.2.
Today i installed Android 4.3 OTA and i forgot to accept the settings which CWM ask you after its installed e.g Yes” if it asks you for root fix or recovery fix.
So therefore eventhough i have all my apps, my rooted apps don't work any longer as the SU binary can't be found according to SuperSu app.
Everytime i open SuperSu installed i keep getting the error:
"There is no SU binary Installed and SuperSu cannot install it".
Also my CWM has been replaced with the stock recovery after the update.
Now i booted my phone into bootloader and it says the following:
SECURE BOOT - enabled
LOCK STATE - unlocked
The boot animation "Google" shows a unlocked padlock.
If i want to install CWM and Su binary do i need to the following?:
****UPDATE****
For anyone else having the same issue as i did. I managed to resolve the issue by following the steps outlined above. Before flashing anything make sure you have the latest adb.exe and fastboot.exe. Backup the data before doing anything! The version of adb i used was 1.0.31 to be exact. Worked like a charm!
I flashed the recovery image and then flashed the latest SuperSu file which supports 4.3. I went back into the SuperSu app and it didnt throw an error.
- Copy latest SuperSU zip file to the device
- Open command prompt/shell and navigate to the folder where the latest adb and fastboot.exe and recovery image exists.
- Backup all the data from the phone to be safe. i used adb backup -apk -all -f nameofthebackup.ab
- Install Custom recovery image
- Flash the zip file
- Reboot
- Choose the option "Yes- to disable stock recovery"
- Check if i have #Su back?
****UPDATE****
