If there is a factory reset protection on the device the only way around it short of flashing factory images would be to enter your account information.
Is there a reason you cannot use your credentials?
usually you can just skip that part of the boot up process....
I have nearly every time, because I want to set up all of my apps and screen before the phone is registered to the carrier...
