Root Residual strangeness from ICS to JB
shyFluttershy
My ICS had been rooted via Poot. I accepted the OTA upgrade to JB and it seemed to go well. I then did a factory reset, so now I'm squeaky clean... ostensibly.
I have not yet begun the process of rooting JB.
When I power off my phone and turn it back on again, I get a yellow triangle with black exclamation point as it's booting up.
Does anyone have any hypotheses?
Thanks.
Yep, it's simply because your phone has been modified. It's more or less a quick way for techs to see if you've voided your warranty or not if you were you send it in for service...most of us in the All Things Root forum probably have it too.
But there are ways to get rid of it, an app called Triangle Away or something like that. I don't worry about it, myself.
Hunh. I thought starting fresh, well, started fresh. Oh, well. As long as Triangle Away or whatever works, I guess I'll cross that bridge when I get to it.
Thanks.
