Ive rebooted multiple times, did another factory reset and still nothing.
I would say perhaps a regional outage, but most likely not the case since I live just south of you and I'm running at full bars 4g, will see if 3g is up. I can't see why unlocking would cause you to lose the ability to activate. not sure what recovery you're running, or I would suggest wiping you cache's and ext's.
Stupid question...did you put the back, back on the phone?
also did you try pulling your sim card and re inserting it
