Resource Monitor apps
Most of what will actually drain batteries are apps that constantly sync. You should shut that off or decrease it's frequency in the app rather than looking for a 3rd party tool that won't be able to do anything but kill the process (which would be bad for your phone).
Do you see some high usage in your logs?
If you're rooted, Greenify does a pretty good job of keeping specific battery-hogging apps from hanging out in the background.
