hiii all, i'm new for 'Android' system..
want to ask that my 'mini pro' issue..
my phone suddenly restart when connected into PC,
please refer into below statements carefully...
- 'notification ringtone' set from micro sd card > connect into PC (by USB) > micro sd card detect on PC > phone restart > SIM couldn't detect > shut down.
- 'notification ringtone' set from InternalMem > connect into PC (by USB) > micro sd card detect on PC > works fine (no anomaly).
-Had formated the micro sd card and replaced w/ another sd card, still found the same anomaly,
-Already re-upgrade into v2.1 (Eclair)
...and had follow instruction that not to insert micro sd card for 24 hours after upgrading process (*although on first upgrade, the dealer directly insert SDcard after upgrade process*)
...but still find same anomaly.
Other function still work fine (i think).
my PC system = XP SP3
Thank you very much for your help in advance
