Help Restarts 3 times then seems to work
linton23
I have a galaxy showcase which is straight talks fascinate. It just started an issue when I start it up it will start up and shutdown 3 times then seems fine. Any idea as to why or a fix?
That sounds like a defective device, linton. I'd return it for repair or better yet insist on a replacement.
Having said that, you can try a factory data reset, which is in the "Privacy" section of the main menu on the Fascinate.
