Help Restore Original IP?
  • Thread starter Thread starter Restore Original IP
  • Start date Start date
  • Tags Tags
    android
R
Restore Original IP
Guest
Being curious (and also very dumb), i decided to change my IP via proxy. When i set it up in the Wi Fi settings, when i clicked the "save" button, nothing else showed up, it didnt show anything about the proxy server anywhere, but my IP defiantely changed. Now I'm regretting it, is there any way to restore my orignal IP address? (I forgot to write it down somewhere)
So presumably you're on a fixed IP address network setup, rather than using DHCP, which assigns you an IP address automatically? And you need the original that's assigned so you can connect?
If so, you'll likely have to get it from your network administrator. Is this an academic or corporate network or something?
Im using my personal Galaxy S6 Edge, and it was a DHCP, as I was given the IP automatically
You need your original IP address back, rather than whatever it gets assigned by DHCP? Have a static IP for the device?
Is there any particular reason you need this, like are you running a server on your phone that others need to access from a known IP address?
I think you'll have to speak to your service provider(ISP), see if they can do anything. Fixed broadband ISPs can often provide a static IP address that doesn't change, but there's usually an extra fee for it though.
I'm not running a server or anything. I'll call my ISP to see what can be done, thanks for your help
