Root Restored Apex...Big problem
irmac
Hey guys, I just restored an Apex 1.4 build that had a honeycomb theme and honeycombed launcher pro plus applied and some reason I can't even get it...It boots up and I get like 4 different things continually force closing. One of them says good on it. Any ideas? I really want to use this backup :(
it just seems that backups cause far more trouble than they are worth. something always wants to have a conflict. i dont even bother with making them anymore, just wipe everything and install fresh. i just keep my ROM's organized in folders with the related theme and custom stuff i make for that ROM. I know this doesnt help any but might give you something to consider.
Yeah thanks good idea, luckily it's not to big of a deal because I think CM7 will probably come out for the X now that the bootloader is being unlocked :)
^what he said
Well, I know it is usually a good thing to do a clean install, but once I install a new rom and then get all of my stuff installed and set like I like it, I make a nandroid backup with bootstrap. I have one for Apex 1.3, Apex 1.40 & 1.4.1, Liberty 1.0 & 1.5, and DarkSlide 4.2. I have moved from one to another by simply restoring my backups and have zero problems at all. I use Droid X Bootstrap Recovery and then select my backup file and restore it. Works great for me.
