Root Restoring backup problem..
highfive
Hy guys!
I recently flash the "new" Redux ZM ROM, I did all the measurements before flashing: backup my apps, with titanium backup and mybackup pro just in case etc.
My problem is that Titanium backup and my backup pro didnt restore the app's data, although on the previous rom I checked the content of the lets say colornote's backup, It showed how many rows I have, notes etc... With the new rom Titanium backup didn't show any of the data that it had shown earlier.... same with mybackup pro
And here comes twist, Colornote has an own backup system. Auto backup was set, and with the new rom it listed the backups nicely, writing the number of contents next to it. Hitting restore, and nothing happens...
The most important would be restoring my notes!
Any help, suggestion would be greatly appreciated! Thank you!
You tiok a nandroid first? Restore that and you have your notes back.
I have known some apps where data don't restore between some ROMs - it is in my experience some apps rather than all. But an app's own backup usually works, so this is odd.
If your backup is safe you could clear data for the app and then restore the backup. Or reinstall from the market then restore the backup.
